I been looking on http://www.cyberpowersystem.co.uk/ and allienware anyone know any other places i can find a top deal at ?
cheers trix
I would build my own it doesn't take a normal IQ to do so, just the will.Ghost wrote:I'm pretty sure that building a computer from scratch is a little beyond Tricky's expertise.
Windows xp 64 bit supports 128 gigabytes, windows 7 64 bit supports 192 gigabytes. Both windows 7 and Xp 32 bit support 4 gigabytes. Even though 64 bit versions support that much ram you'd never be able to use it.Gmanson wrote:Windows 7 can support up to 128 gigs. Windows xp can not support more then 3.5 to 4 gigs is probably where you got that from.
Had a problem similar to that.... one of the sticks wasn't booting I dont think BC2 would really take up 4 GB since SC2 and MW2 only go a little over 2GB, if you open up task manager and check your Physical Memory it probally would have said 2026 MB ( Something close to 2048 ) instead of the 4096 you should have, dont know why it did that sometimes it booted both sometimes it booted 1, thus making every game laggy, reseat the sticks that worked for me, that is if you really need 8 instead of 6inola wrote:Windows xp 64 bit supports 128 gigabytes, windows 7 64 bit supports 192 gigabytes. Both windows 7 and Xp 32 bit support 4 gigabytes. Even though 64 bit versions support that much ram you'd never be able to use it.Gmanson wrote:Windows 7 can support up to 128 gigs. Windows xp can not support more then 3.5 to 4 gigs is probably where you got that from.
I built my comp with 4 gigabytes of ram which is plenty with page file set off. A friend of mine gave me 2x2gb ram sticks so now I have 8gb. For some unknown reason battlefield bad company loads instantly now instead of it taking 2+min so I took the ram out and tried without it again same shit the game loads slower with 4gb instead of 8gb.
It's a mystery I've yet to understand the ram sticks are same brand, timing and speed maybe it's a chipset thing.
