cannot play wiith new patch
smarty
I have already long problems with the new patch , since then i cant play anymore. I reinstall it all and now i get this error when i do auto update
- X warrior411
Re: cannot play wiith new patch
Looking at the update log, it seems like it couldn't find your AoC directory, try manually putting it in the address bar thing on the bottom, also make sure your running it as an Administrator.
Go to the PatchUpdate.exe file (location is in the error message), right-click on it, and hit "Run as Administrator"
After that you can then try using the Auto-Update function and everything should be OK
smarty
smarty
[10:51:44] -Ápø¢ałýpsэ-Smarty- whispers to you: it works now
[10:51:46] -Ápø¢ałýpsэ-Smarty- whispers to you:
[10:52:01] -Ápø¢ałýpsэ-Smarty- whispers to you: I did some things there, some things there , and then it worked
Problem solved, apparently.
