New set : i4n
uIwehFx
- Lobby Username: uIwehFx
New set : i4n
For me personaly there was to much pre and to much gren in the lobby. I had some thoughts on a new set. Basically i wanted to avoid Liga starting in the ages pre-imp. Thatswhy i put the settings, on imp to nano ( imp 4 nano ). So bascially it stays in tl with 5 cits.But to avoid making it a imp tl unticked the custom civs. And to avoid making it liga i ticked the reaval map. So you will bascially playing a liga with reaval map starting in imp.
This set is quite hard to play, too, i wanted a new sheme in the set , that it is close to liga doesnt matter because the reaval map will change the starts more to an regular tl. I think this set is really nice, i tried it yesterday several times and it is just working amazingly. I will host some during the next weeks and watch how it goes, i would be glade if you wanna play some too.
I called it i4n because i did not want to call it i2n to not copy the pre name to close. And i didnt want to choose a random name , because noone would understand the titel and know wat i mean , in the lobby.
Settings :
- Imp to nano
- 5 cits , tl
- Tournament
- Map : Plains
- Countries as civs
- Reaval map
Basically the important things.
Settings :
- Imp to nano
- 5 cits , tl
- Tournament
- Map : Plains
- Countries as civs
- Reaval map
Re: New set : i4n
i like people trying to create new setts but its extremelly hard as people are too stubborn to play them.. gud luck to u but personally that sett wudnt befor me as im not a fan of imperial in liga to begin with. also the problem u have choosing no custom civs is that there is only really 3 civs anyone wud pick. austria, spain and assyrian(if ur noob)
uIwehFx
Re: New set : i4n
you could also use mod civs , and try to defend and age fast... it would work quite well i guess, i tried it and it did work out to be good enough.
Re: New set : i4n
Everyone would just do no settle halb rushes with Austria because the reveal map will allow you to see where your iron mine and hippos are.
- PeLlE
- Xfire: thepelie
Re: New set : i4n
citrush would work fine too unless ur no sett halb rushed
eww mixed it up with ren ^_^ DUnno if citrush works in imp but in ren its amazing
uIwehFx
Re: New set : i4n
There at least is some people willing to play it, and i even know people who really like it , so just try it...
devilridermax
- Lobby Username: devilrider
Re: New set : i4n
it sucks... i played you
i no settle rushed and beat you and your teammate......? idk.....
no settle rushing is just to easylol
uIwehFx
Re: New set : i4n
So ? I played against many people in it , and lost some, doesnt mean the whole set sucks , your point is just trying to kick my nervs.
If you say i4n sucks than you say indy tl sucks either , you can easily rush people with no settel, and sometimes it works out well. You can do this really good in ind tl, too. JUst the point is when i have a nice spot with a nice tower covering a lot, your no settel start will just fail. SO whats your point ? Beating me with a no settel start means that the set sucks ? Pathetic...
devilridermax
Re: New set : i4n
i was kinda implying that this set will be based around no settle rushing..uIwehFx wrote:So ? I played against many people in it , and lost some, doesnt mean the whole set sucks , your point is just trying to kick my nervs.
indy tl is fine.. because the CR for building really works in the favour of the 1 settle player more then the no settle, its still hard ,but its defeinatly still effective....
industrial would elimnate spear rushers
and would improve the boom parto f the setting
but really you cant imply this complete nonsense
there completely differetn
"If you say i4n sucks than you say indy tl sucks either"
imperials such a drag of an age.. lol,
do you age in indy tl?
do spears 2 hit kill cits?
you have custom civs?
uIwehFx
Re: New set : i4n
Your points are just rediculous. It will be easier to defend a no settel rush in i4n than in indy , obviously. Without settel you will have a massiv resource probelem after your 2nd unit in i4n, in indy tl you have the right civs to be able to. No civ is giving you opertunity for fast gold + fast food. Also your units will never be perfect for rushing , lack of range , lack of attack to kill cits fast... this is all points that it make it harder in i4n to no settel rush than in indy tl.devilridermax wrote:i was kinda implying that this set will be based around no settle rushing..uIwehFx wrote:So ? I played against many people in it , and lost some, doesnt mean the whole set sucks , your point is just trying to kick my nervs.
Really that you won vs me with no settel rush was probably because i did a 2 settel rush without any possibility to rush. Or my spot was just horrible.
And i can just say that the rush in imp will be quite similar to the rush in indy
- Sexacutioner
Re: New set : i4n
it would just take coulpe liga players to join your game and show you how easy it is to rush in imp, after all they play that age quite a bit as it is and know the civ/strat to use for that epoc
uIwehFx
Re: New set : i4n
I play liga my self , so i knew imp and the start + civs before.
But i am not sure what you both mean ?! I mean is it bad playing a age where you can rush, or were cav is bad ? I mean it doesnt matter really , you age with 180 and 180 of gold/iron and 365 food i think. So the ageing occurs around f11 12-15 depense on how the game is going. And in indy , cav is quite strong, so things turn around.
I really dont want to start arguing in this topic as well. If you think it is worth playing it , play it , if not just leave it. The set is just the set now
- Sexacutioner
Re: New set : i4n
but a rush is usually around 4-5 f11 so if the other guy is just booming hes most likely dead
Users browsing this forum: No registered users and 53 guests
