Test Patches in Zip Format
Staff will post any new announcements in this forum, which can be discussed by other users.
EE Changes:
  • -Tribute screen removed (Test change)
AoC Changes:
Permanent AoC Changes (as per votes from the last poll--yeah, I threw these in here too because they're long overdue):
-ICBM Cost reset to default
-All civilization power changes reset to default
-Flaming arrows civilization power reset to default
Download and extract to your installation directory. These will be available from the patcher in the lobby shortly.
Download links for Zips:
EE: removed -- test over
AoC: removed -- test over
Re: Test Patches in Zip Format
Further notes:
Your full version numbers in the top left corner of the main menu should be:
EE - v2.00.4474
AoC - v1.00.7384
I've tested the Patcher program and everything went smooth with updating to the new version. If you can't get it to work, run it as administrator (right-click -> Run as Administrator, on PatchUpdate.exe) and then hit the buttons in the patcher in this order:
1. Force Patch Update
2. Copy Patch Files to Install Directories
Return to “Announcements”
Users browsing this forum: No registered users and 14 guests
