Can't build docks?
MrKen
Lobby Username: MrKen
Can't build docks?
Post by MrKen »
I started a random game, with some space terrain and also added water.
Now when I enter the Stone age, I somehow cannot build any Docks...
Is there any option to enable? :(
Ennemy player somehow does build docks tho..
Re: Can't build docks?
when there's space in a map, the game assumes your playing a space game, and 'space docks' replace normal docks.
You might try to add docks in scenario editor :)
This is not surprising. A map with space and water terrain was intended to be impossible as per map scripting. The dock and space dock buttons are obviously exclusive to the appropriate map type. The game thinks its a space map, and as such will not allow you to make docks, because the button is not there for you to press.
The computer can still make docks because they're not limited by the user interphase.
You can get your own docks if you manually add them from the scenario editor.
Alternatively, you can take an islands random map game and add space terrain, then you can build docks! Just don't complain when it hits space and you cannot make any space docks :P
MrKen
Post by MrKen »
Somehow sometimes in the test games, I am able to build docks tho...
I try this now and continue from a auto save game.
Hope it works.
Why would you need both water and space?
devilridermax
Lobby Username: devilrider
Post by devilridermax »
water to drink
MrKen
Post by MrKen »
PeLlE wrote:You might try to add docks in scenario editor :)
Good idea, I did this! :) Thanks!
Why to need water? Caus I like the Dock defending.
Tho I also like the space invading.
Users browsing this forum: No registered users and 70 guests
