And again and again
I have the problem now
EE lobbyclient icon i cant find it
i downlloaded like 10000 times that fucking update
there is no link here to download the lobbyclient only
so i cant play EE
No Lobbyclient
Re: No Lobbyclient
The LobbyUpdate.exe file should be automatically downloading the other requisite files and placing them in the exact same location as it is located in when its run. It should also run lobbyclient.exe immediately after it finishes.
When you run LobbyUpdate.exe, after it finishes normally, what exactly happens? Nothing? Do new files appear in the location it was run? Does it try to run lobbyclient.exe? Do you get an error? If so, EXACTLY WHAT DOES THE ERROR SAY AND WHEN DOES IT OCCUR? Does it actually run lobbyclient.exe and if so do you get to the login/create new account screen? If it does not finish normally (i.e. you get an error), please tell us exactly what the error says. Et cetera.
More detailed information is key, since from all you've given us all we can tell is:
1) You are upset.
2) You have tried doing something multiple times.
3) You can't find the icon for the lobby client.
4) You can state the obvious.
#1 doesn't help us solve your problem.
#2 also doesn't help us. It most certainly would if you described exactly what you've been trying, and exactly what the results have been, but you didn't.
#3 Still doesn't help us because you didn't describe exactly what you've been trying and the results of said attempts. It could be you're too dumb to even RUN the updater (doubtful, but if I read your post literally, this is exactly what you have described). Or maybe you're running the updater but are failing to locate the lobbyclient.exe file for whatever reason. Or maybe the updater isn't running properly for some reason, et cetera. We really have NO idea based off of the information you've given us.
#4 also doesn't help us. We know there is no link to download only the lobby client, and there is a very good (and obvious if you think about it) reason for why this is so. We also know you're not able to play EE through the lobby if you can't get on the lobby client.
1) You are upset.
- PeLlE
- Xfire: thepelie
Re: No Lobbyclient
Try to remember where you saved the lobby update is my suggestion.
Re: No Lobbyclient
pages.php?p=lobby-guides#lobby-install
Go there. Read it very very carefully. It tells you that you must save it to a dedicated folder. When you run it, a shortcut icon is not created. On the page I linked you to, it also shows you how to create a shortcut icon.
If remembering the location you put the lobby is all too hard for you, then save LobbyUpdate.exe to your Desktop and then you can run LobbyClient.exe from your Desktop every time you want to play.
uIwehFx
- Lobby Username: uIwehFx
Re: No Lobbyclient
It doesnt matter where you saved it , you just press earch in all folders , and tip in : LObbyclient , it will come up...
Users browsing this forum: No registered users and 45 guests
