Lobby Run Error - read the entire site still stuck!
(AoW) Necro
Lobby Username: Necro
Post by (AoW) Necro »
System.ArgumentException: Value does not fall within the expected range.
at System.Windows.Forms.UnsafeNativeMethods.IWebBrowser2.Navigate2(Object& URL, Object& flags, Object& targetFrameName, Object& postData, Object& headers)
at System.Windows.Forms.WebBrowser.PerformNavigate2(Object& URL, Object& flags, Object& targetFrameName, Object& postData, Object& headers)
at System.Windows.Forms.WebBrowser.PerformNavigateHelper(String urlString, Boolean newWindow, String targetFrameName, Byte[] postData, String headers)
at System.Windows.Forms.WebBrowser.Navigate(String urlString)
at LobbyClient.FormLobby.FormLobby_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
LobbyClient
Assembly Version: 2.6.1.5
Win32 Version: 2.6.1.5
CodeBase: file:///C:/Sierra/EE%20Lobby%20Client/LobbyClient.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
LobbyShared
Assembly Version: 2.6.1.0
Win32 Version: 2.6.1.0
CodeBase: file:///C:/Sierra/EE%20Lobby%20Client/LobbyShared.DLL
Language
Assembly Version: 1.0.4.1
Win32 Version: 1.0.4.1
CodeBase: file:///C:/Sierra/EE%20Lobby%20Client/Language.DLL
Network
Assembly Version: 1.0.1.1
Win32 Version: 1.0.1.1
CodeBase: file:///C:/Sierra/EE%20Lobby%20Client/Network.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
CustomPanels
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Sierra/EE%20Lobby%20Client/CustomPanels.DLL
enabled.
For example:
<configuration>
</configuration>
Fix it guys :p
Thanks
Re: Lobby Run Error - read the entire site still stuck!
Apparently it's having trouble navigating to "about:blank" which is a pretty standard for IE. .NET uses an integrated web browser which is an implementation of IE.
Do you have Internet Explorer installed? If not, installing it will more than likely fix it.
(AoW) Necro
works :)
thnx ghosty poo.. u still play or jus do lame mod stuff?
oh n u in touch wit wes n the others?
Yeah, I still play but not much. Contact with Wes comes and goes.. not many of them still play.
get back on necro u noob
SlipKnoT wrote:get back on necro u noob
Thread res for something a PM would suffice for...
Locked.
