Signature
USOLA
Xfire: usola
Lobby Username: usola
Signature
Post by USOLA »
i want to know how to upload a signature through user control panel?
Re: Signature
User control panel -> Profile -> Edit Signature -> put URL to image in image tags.
How to upload an image somewhere else? Use any of the numerous sites that allow free image uploading, etc. (Which is the link you put in the image tags for your signature...)
Re: Signature
1. Go to http://www.imageshack.us/
2. Upload image
3. Get the DIRECT URL TO IMAGE from the result page
4. Go to signature page in your UCP and put in the code:
Code: Select all
[img]http://direct.url.to/your/image.ext[/img]
Re: Signature
One does not simply upload his signature!
Re: Signature
Re: Signature
lolz
USOLA
Xfire: usola
Re: Signature
Post by USOLA »
Ghost wrote:1. Go to http://www.imageshack.us/
2. Upload image
Code: Select all
i've tried this and couldnt upload my signuature
Re: Signature
2. Upload image
Code: Select all
Failz
You don't upload it to here, you upload it to Imageshack/Photobucket/whatever, then you put the image code where your sig would be in Control Panel.
USOLA
Xfire: usola
Re: Signature
Post by USOLA »
ive tried Imageshack/Photobucket to upload and they fail upload due to invaild format
Re: Signature
USOLA wrote:ive tried Imageshack/Photobucket to upload and they fail upload due to invaild format
...then change the format to something they accept lol
Re: Signature
Change it to a good format, depending on what you need.
png. is good for quality images.
gif. is good for animations.
Some of the more commonly used formats are bmp., and jpeg. however, it won't be as high quality of PNG, so I recommend PNG.
You can change the format very easly by opening your image in an image editing program (It can be any, even MS paint), save it to one of the formats listed above, then upload and your in business.
Re: Signature
Use .png, it doesn't have nearly as much compression as .jpeg, but it allows transparency, and it isn't a lossy format.
Re: Signature
peow130 wrote:Use .png, it doesn't have nearly as much compression as .jpeg, but it allows transparency, and it isn't a lossy format.
^ What he said.
Re: Signature
You're trying to upload an XCF file, which is the native GIMP format. You'll need to open it up again and "Save As" as different file type such as JPG, PNG, or GIF (you shouldn't use GIF for a signature). Then, you'll want to upload that new file to ImageShack.
Unless your signature requires transparency, use JPG because it's a more web-friendly format.
Here's a side by side comparison of my signature in PNG and JPG formats. There is absolutely no visible difference in quality, however the JPG has a slightly smaller file size.
PNG format
High quality JPG format
down there vvvvv
Re: Signature
Oh, you can get high quality .jpgs. I do it all the time in my photography class, lol.
Users browsing this forum: No registered users and 14 guests
