obtaining server ip
USOLA
Xfire: usola
Lobby Username: usola
Re: obtaining server ip
Post by USOLA »
Ghost wrote:As of right now, I am not aware of an error on my part that causes this problem. USOLA has the same problem and has either A) solved it and not told us how he did it or B) stopped seeking support from us for now.
From now on, you need to USE PUNCTUATION if you wish to seek support from us. im not going to halp teh ppl who decide to tlk like this in big huge runon sentenencences with shit speelling HELP and r like omg wtf shit donet work so plz fix it kk bye help :*****( If you want support, act like it.
You also need to provide us with some detailed information. Have you changed anything recently on your computer that might have started this problem? Also go through some of the other shit that I've asked USOLA in this topic. I don't feel like repeating it...
ive stopped seeking help for now......ive changed nothing expect for removing stufff from my computer....i started to remove stuff after the problem started not b4...the problem started hours after ive a play a game on ee
USOLA
Xfire: usola
Post by USOLA »
i was going throught both the patched and unpatched ee-aoc folder and i noticed i have a zipped folder of the ee lobby version 1.0.6 (under the sierra update folder) and i wondering if that folder has something to do with my situation...btw i tried to logg on to that lobby and got 'unable to contact server'....and i dont have it for the eec folder
That doesn't have anything to do with it lol. And that's expected that you can't join with earlier versions of the lobby since it's programmed to not let you ;) (not to mention that v1.x won't even work with v2.x)
USOLA
Xfire: usola
Post by USOLA »
Ghost wrote:That doesn't have anything to do with it lol. And that's expected that you can't join with earlier versions of the lobby since it's programmed to not let you ;) (not to mention that v1.x won't even work with v2.x)
ok just worrying :lol:
USOLA
Xfire: usola
Re: want let me connect plz help
Post by USOLA »
Ghost wrote:Your lobby must be able to access a certain file on this website in order to obtain the server IP. Have you made any changes to your firewall lately?
which file is this?
Regardless of what it's called, if you're able to read this page then you're able to get that file. The question is more aimed at whether or not your computer is allowing a program (other than a browser) to access it.
DeadGeekWalking
Post by DeadGeekWalking »
Hello,
I'm running Windows 7 32bit. I've got .NET 3.5. I've reinstalled it twice. I'm behind a router, but think I have disabled that firewall (which ports does the Lobby use?). I've turned of Windows Firewall.
I'm having a similar problem. I installed the Lobby. When I try to play, it goes through the "obtaining announcements/smilies/etc" until it comes to the line about updates. It then attempts to search for updates (and, I assume, fails), and restarts.
I think this problem has something to do with something on my side blocking the programs access outbounds. Do you have any suggestions to test this, or what might be blocking it? Or another idea?
Thank you in advance,
DGW
-edit- I think that part of the error report requires a new thread, if an admin/mod is moving the question, please move this along with it.
DeadGeekWalking wrote: I'm having a similar problem. I installed the Lobby. When I try to play, it goes through the "obtaining announcements/smilies/etc" until it comes to the line about updates. It then attempts to search for updates (and, I assume, fails), and restarts.
I've had the same problem on my old Windows Vista (Home Premium) computer (which no longer works),I don't know why but there is a workaround to the problem.
<Very Short version-Download from 3rd party>*
Below this post there will be a link from Omega to a file sharing website, download the lobby + it's data and files, then uncompressed if needed, place in a good spot, and your done, Thanks Omega.
* Untested
<Short version-Email>
Find someone who's willing to Email you a copy of the lobby application along with it's files.
Have them Email you the lobby, download to the computer (might be compressed, if so, un-compress it)
Put the lobby folder in a good place, run it, and your good to go...
<Short version-Two Computers>
If you have two computers and one of them can run the lobby, but can't on the other and you need to for whatever reason (e.g. EE runs better), use this.
Copy the lobby, and all of it's data, into a folder, compress if needed, then Email it to yourself (on the computer that runs it), to the other one (which it doesn't...sorta), then open your email you sent to yourself, download and uncompressed if necessary, put it in a good spot, run, your in business.
And yes, future updates will install with no problems, this is true to both methods.
The Email method has been proven, it was how I got the lobby on my old Vista.
<My case on this problem and how I got around it>
This tells how I got the lobby to run on my (old) computer. Not very relevant but might help find possible causes.
When I found out about Save-ee.com, the forums, and the lobby, I downloaded the lobby (onto my old-er computer which ran Windows XP), and it worked, but the computer was kinda crappy,slow,ect. So why not install EE (I still had the disks back then, and yes, I bought EE), EE's installed, then I install the lobby......but it doesn't work, It runs, installs, then it updates...which repeats over...and over...and over again nonstop. I went over to my XP, which ran the lobby, logged in, and asked a Moderator/Admin for help (too bad I forgot who helped me). He then offered to Email me the lobby and the files for it, I gave him the Email, he emails me the lobby (He also tells me to delete some data which now I know it's the data which stores the user-names), I run it, and it works, and worked always... Updates install successfully, and no problems, I guess the problem was the installer/updater.
<Other info>
I installed the lobby onto my new (current) Windows Vista computer, and everything worked fine without assistance.
I think the cause, judging from the two computers, is likely a security thing, my second guess is something to do with hardware.
It's Not the OS. (Vista isn't as bad as everyone says)
(By copy of the lobby,I don't mean the installer which you download off Save-ee, the FULL lobby and it's data, which is what installer installs onto your computer)
If your lobby is repeatedly updating, it sounds like you're getting some bad hashes for the files.
Here's a link to a zip file that contains all lobby files. Extract to a dedicated folder and you're ready to go.
http://www.eeaoctraining.com/save-ee-lo ... .6.1.3.zip
Let me know if the problem still persists.
DeadGeekWalking
Thank you very much!
I got the lobby running well. I now have confronted a new problem. I am getting the "your game version does not match hosts'" when trying to join games. I have attempted to solve this problem with two reinstalls, including one from my original (circa 2002-3) cd and from an a hacked torrent version. I have applied the patches. The game version that shows up in my upper left hand corner says v2.00.3466.
Any thoughts?
Most players are using Omega's patches. viewtopic.php?f=2&t=1027 After applying it your game version will be the same.
DeadGeekWalking
USOLA
Xfire: usola
Post by USOLA »
i cant explain how but i was able to logg on to the lobby today
USOLA wrote:i cant explain how but i was able to logg on to the lobby today
Did anything change with your computer or settings?
Perhaps you closed an anti-virus or firewall program that usually runs sometime before trying to log into lobby?
USOLA
Xfire: usola
Post by USOLA »
i havent close or change anything....
