edit: downloaded the new lobby update and it works
When I try to run the lobby exe I get "Startup error- Please check your internet connection."
When I try to run the lobby update exe I get "Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately. No connection could be made because the target machine actively refused it 129.0.0.1.5555."
and when I click continue, the lobby update will run but never updates.
I'm trying all this without any security software running at all.
I've re-downloaded the lobby files already.
Help?
Can't connect to the lobby server
Wyrda
- X warrior411
Re: Can't connect to the lobby server
I couldn't last night, but now I can, no problems...
I guess it fixed itself/they were doing lobby stuff.
Wyrda
I still get the same error messages thoughX warrior411 wrote:I couldn't last night, but now I can, no problems...
Please click on the details button and paste the full error here.
Wyrda
ah, i was wondering if I should include that. SorryGhost wrote:Please click on the details button and paste the full error here.
System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:5555
at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Int32 timeout, Exception& exception)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3603 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
LobbyUpdate
Assembly Version: 1.1.7.2
Win32 Version: 1.1.7.2
CodeBase: file:///C:/Documents%20and%20Settings/-/Desktop/LobbyUpdate.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Windows.Forms
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
enabled.
For example:
<configuration>
</configuration>
Well I've looked it over... I can't figure it out... it looks like it's having trouble downloading anything from this website (update info, server info, obtaining IP, etc.). What's throwing me for a loop is the localhost IP address, so maybe it's trying to get this information from cache?? Try clearing Internet Explorer's cache, temp files, etc.
So, think of reasons why it can't access this website. Try "Run as Administrator" and make sure a firewall isn't blocking either program. The problem is on your end..
Wyrda
I tried those things, none worked. I have no firewalls or anything running so I'm not sure what else to tryGhost wrote:Well I've looked it over... I can't figure it out... it looks like it's having trouble downloading anything from this website (update info, server info, obtaining IP, etc.). What's throwing me for a loop is the localhost IP address, so maybe it's trying to get this information from cache?? Try clearing Internet Explorer's cache, temp files, etc.
Thanks anyways...
