Neo-EE
Snouk
- Lobby Username: Snouk
Re: Neo-EE
What is the fix for the cd-key error please? I still can not get the patch in correctly with working cd-key
Re: Neo-EE
Sent you a PM.
Snouk
Re: Neo-EE
I have download and install the new patch from neo-ee and my cd-key is still not working. I am afraid that I will need to uninstall the game reinstall from the hard CD's reenter cd-keys and use only the latest patch from neo-ee. I will not accept anybody programmed key fixer thru pm. Sorry!
Re: Neo-EE
No, this won't help you at all. What error message comes from the new patch installer? Also, go to your Empire Earth folder and search for the file "WONLobby.cfg". Open it with a text editor and change the line CDKeyCheck: false to CDKeyCheck: true if not.
Snouk
Re: Neo-EE
I just uninstall ee-aoc and reinstall and enter my cd-kay. Now I just open neo-ee folder and run neoee-aoc and it connects and plays multiplayer just fine.
ConquerorX
- Lobby Username: ConquerorX
Re: Neo-EE
Hey all-
I just want to say thank you to all those who contributed to bringing this fun game back to life.
Well done! and Thanks!
tool
- Lobby Username: (Zabijej) Tool
ConquerorX
ConquerorX
Re: Neo-EE
Diaco
- Lobby Username: Diaco
Re: Neo-EE
I can't create an account.... What do I do?
Re: Neo-EE
Install the patch and use the shortcuts created on your desktop.
Tissue
Re: Neo-EE
Hi, Ever since installing the Neo-EE patch, empire earth crashes within 5 minutes of opening it. Sometimes its right at the main menu or sometimes its a few minutes into a multiplayer match. I did not have this issue before installing the patch. I just did a fresh install of EE again and reapplied the patch and then as soon as I opened EE it stopped responding. I've noticed that after applying the patch all my graphics settings are reverted to the defaults, and for some reason EE opens on my 2nd monitor instead of my primary. I'm not really sure if that means anything but I figured it was worth noting. I've also tried the game in multiple compatibility modes, none have had any effect. Has anyone else had this issue?
Re: Neo-EE
So there is something wrong with your ee.exe, I would suggest just reinstalling (maybe use a different download) and if there is any errors under installing u should report to jodocus about that.
Tissue
Re: Neo-EE
I installed it from my CD. There where no errors when installing it either.
Re: Neo-EE
The binary is getting replaced by the patch. Try every single graphic option inside EE. Try different colour depths. Try down- or upgrading your video card driver. If you have installed multiple installed GPUs, try them.
