Install Fail
DELUX
Lobby Username: DELUX
Install Fail
Post by DELUX »
So ever since I've had this game the expansion has had a tough time installing because it says the cd does not have data2.cab, and always stalls while installing leading to the crash to the program. Anyway I can fix this?
simple_faith
Lobby Username: simple_faith
Re: Install Fail
Post by simple_faith »
First, of all. When you your installing it try to change the location of the install directory because I had to this problem before and that fixed it, the original install location of it should be set to C:\Sierra, change it to C:\Program Files\ and it should work if not, your CD which I think your using to install is scratched up so I suggest downloading it from here.
DELUX
Re: Install Fail
Post by DELUX »
Where can I find the download?
Because the crack is worthless since it won't fully install.
simple_faith
Re: Install Fail
