HOSTING PROBLEM Help
Posted: Sat Apr 06, 2013 7:22 pm
by [-Ts-] Tricky
green-man whispers to you: Hello. i got a problem. i can host on all other computeres in the house but i cant get it work on my original one. i know something i can try to get it work?
Anyone got any ideas how to solve this problems :) thanks for any help provided
Re: HOSTING PROBLEM Help
Posted: Sat Apr 06, 2013 7:44 pm
by Lancelot5
whisper me in Lobby i will try to help. But remember due to bad routers u mostly only can open Ports for 1 PC in a Network which leads that only 1 PC is able to host.
Posted: Sat Apr 06, 2013 7:57 pm
by herik
Turn firewall off, make sure ports are correct 33337, ask if he using wireless or router.
Posted: Sun Apr 07, 2013 5:38 pm
by Sexacutioner
you have to give that computer access through your main comp running everything
Posted: Sat Apr 13, 2013 2:21 pm
by monpablo*_
check your router settings to make sure you connected all entries to each other. what do you mean by "all other computers". if there are at least 2 other computers in that network able to host id say there is another problem. if youre able to connect over different network connections choose the right adapter in game settings+save-ee lobby. check if your computer is connected to the router with a cable instead of wireless if using. else you missed a local firewall option. controlpanel -> firewall can help. dont use permissions for special programs kill it with fire
