Lobby install error
Posted: Thu Nov 19, 2009 1:42 am
by Samurai
I recently just installed empire earth again, this time to test the multiplayer, except I get this error when I try to run the "Save-EE Lobby Update 1.1.7.2" and to install updates:
I'm currently running Vista with COMODO firewall, any help with resolving this issue would be very helpful!
Also here are the details of the error:
Code: Select all
System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 74.208.159.29:80
   at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
   at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Int32 timeout, Exception& exception)
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4200 (NetFxQFE.050727-4200)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
LobbyUpdate
    Assembly Version: 1.1.7.2
    Win32 Version: 1.1.7.2
    CodeBase: file:///C:/Users/Owner.Samurai-PC/Desktop/LobbyUpdate.exe
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.4016 (NetFxQFE.050727-4000)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System.Windows.Forms
    Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
enabled.
For example:
<configuration>
</configuration>
Re: Lobby install error
Posted: Thu Nov 19, 2009 5:53 am
by Ghost
74.208.159.29:80 is the HTTP address that this website is hosted on. Make sure your firewall is allowing the update exe to access the internet.
Posted: Thu Nov 19, 2009 3:19 pm
by Samurai
Ah, thanks a lot! All I had to do was "define a new trusted application" with my firewall.
