Page 1 of 2
[Ak]Middle Sh Ca cloak
Posted: Sun Aug 22, 2010 9:28 am
by ak_47
This civ is my 1v1/2v2 civ, you can either go persians or ca, i usually make a dog to scout what the enemy is making. if the enemy makes swords, ill build persians, if they go ca, ill counter with ca+balistas. The purpose of having cloak is to make it harder for your enemys to kill your eco and army.
This civ is an alternative style of playing, it's hard to use and is not recommended for beginners.
if you wanna have a better civ go look for a ca exp civ.
Re: [Ak]Middle Sh Ca cloak
Posted: Tue Aug 24, 2010 3:31 pm
by Eisregen
hm better made a expan ca civ much better
Posted: Thu Sep 02, 2010 8:33 am
by Arntzen
This could work if u send nonstop cavs to ur enemie base and hit him as much as passible. I would maybe swap Cav attack for btd to get cavs faster. Cloak is defending ur base so there is no reason to sit on ur ass.
As for the 2v2 this could work if either ur enemie are worse than u and ur ally or if both on ur team do cloak. (if not, ur enemie will only dobble ur ally
Posted: Sat Sep 11, 2010 7:59 am
by Absolutely
Kazter wrote: I would maybe swap Cav attack for btd to get cavs faster.
Ca w/o atk won't deal enough damage to swords with 6+5 on arrow.
And tbh I don't think that cloak will work vs. decent enemies. Furthermore even trying to annoy your enemy by hitting his ressources with ca won't work if you don't have btd nor expan to increase your ca production.
Posted: Sat Sep 11, 2010 8:35 pm
by Arntzen
Absolutely wrote:Kazter wrote: I would maybe swap Cav attack for btd to get cavs faster.
Since I wont have CA attack in civ, I will after a while swap over to persians if I'm vs a player with swords.
And Ecokill/annoying ur enemie will be very passible with a civ who got cr/btd on cavs and gold mining, but vs a ca player u might have to use 2 or even 3 groups. Just remember to dont loose cavs, allways run back if they hit you.
But I will agree on that a normal ca civ or ca expan civ would in most cases be better, but all I'm saying is: CA cloak could work.
Posted: Sat Sep 11, 2010 9:40 pm
by Ghost
Personally I think cloaking does not help a lot in a CA civ because when you play vs. a normal CA player he can still rape the shit out of you with ballistas by using attack ground. Against a sword player you'd probably be better off just simply walling up in a team game or using a civ with BTD in 1v1.
Posted: Wed Sep 15, 2010 10:08 am
by Hello0
U probably just win with this civ when ur enemy alt+f4s cus hes too pissed to play vs this.
Posted: Fri Sep 17, 2010 10:59 am
by Absolutely
Persians without attack suck. Get knights instead of pers
Posted: Tue Sep 21, 2010 5:02 am
by Arntzen
Ur saying knights without any uppgrades is better to use than persians with btd, cr, speed and range in a cloakciv vs sword slut and sword expan?
Posted: Tue Sep 21, 2010 7:21 am
by Absolutely
Kazter wrote:Ur saying knights without any uppgrades is better to use than persians with btd, cr, speed and range in a cloakciv vs sword slut and sword expan?
yes , I do
Posted: Tue Sep 21, 2010 3:06 pm
by Arntzen
Can you please explain why?
Posted: Wed Sep 22, 2010 8:04 am
by Absolutely
Kazter wrote:Can you please explain why?
Knights are more effective vs swords than persians without atk.
Posted: Wed Sep 22, 2010 8:35 am
by Arntzen
Absolutely wrote:Knights are more effective vs swords than persians without atk.
I disagree.
In my opinion getting knights in a cloak civ is just stupid. The reason u have cloak is to make it much harded for ur enemie to eco u. In a way it works as a wall. So vs a swordslut or swordexpan player i would get persians for 3 reasons:
1. Because u got btd and cr in civ for pers/cavs u can pop out cheap pers fast. U also got speed in civ which means ur enemie wont be able to touch ur persians if u use em right (cavarly arrow with speed + cloak pown knights with nothing vs swords IMO). And with the persians u can push into ur enemies base or let him feed u swordkills.
16 pers can eat alot of swords/citz while 14-12 knights wont do much damage because of the towers/houses ur enemie will have in his base are gonna help his swords defeating em.
2. The biggest threat to cavarly range+cloak civ IMO is balista because of their "attack ground" which can hit u even tho ur base is cloaked. Ur persians can kill their balis without getting attacked by his swords, but he can easyer micro and kill some knights.
3. Pers are better for killing heros, buildings and towers.
Posted: Thu Sep 23, 2010 3:20 am
by Absolutely
Kazter wrote:Absolutely wrote:Knights are more effective vs swords than persians without atk.
I disagree.
You're just describing tactics about how to defend your base.
IMO there is no reason in defending while your enemy is able to boom.
I'll post my whole reply later.
Posted: Mon Oct 04, 2010 8:23 am
by LacRimoSa
pers+sword > knight+sword
Sure, knights got more attack, but with pers u got the ability to hit'n run.
I always mix pers to swords. Never regretted it. However, it depends on the playing style too, if you just ctrl walk, straight to enemys base, knights are the better choice.
In this case, with a cav bow civi, no doubt pers are the better choice.
Lg LacRi
