Anyone got any ideas how to solve this problems
HOSTING PROBLEM Help
green-man whispers to you: Hello. i got a problem. i can host on all other computeres in the house but i cant get it work on my original one. i know something i can try to get it work?
thanks for any help provided
Lancelot5
- Lobby Username: Lancelot5
Re: HOSTING PROBLEM Help
whisper me in Lobby i will try to help. But remember due to bad routers u mostly only can open Ports for 1 PC in a Network which leads that only 1 PC is able to host.
herik
- Momma's boy
- Lobby Username: herik
Turn firewall off, make sure ports are correct 33337, ask if he using wireless or router.
you have to give that computer access through your main comp running everything
- monpablo*_
- Lobby Username: monpablo
check your router settings to make sure you connected all entries to each other. what do you mean by "all other computers". if there are at least 2 other computers in that network able to host id say there is another problem. if youre able to connect over different network connections choose the right adapter in game settings+save-ee lobby. check if your computer is connected to the router with a cable instead of wireless if using. else you missed a local firewall option. controlpanel -> firewall can help. dont use permissions for special programs kill it with fire
