Stuck @ Checking for Updates..
Post by ben55 »
It just checks for updates then goes to a cmd prompt looking thing then back to checking for updates over and over and over. It worked about an hour ago now it does this.
Re: Stuck @ Checking for Updates..
Uh just close out of it and try it one more time and if it keeps doing it then just download it from here and replace
lobby/LobbyClient.exe
Post by ben55 »
I did of course try more than once lol.. I tried re-downloading it says "access to the path userprefs.txt is denied"
Post by ben55 »
System.UnauthorizedAccessException: Access to the path 'C:\Program Files\Mozilla Firefox\userprefs.txt' is denied.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.File.Delete(String path)
at LobbyClient.FormLogin.LoadPrefs()
at LobbyClient.FormLogin.FormLogin_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4200 (NetFxQFE.050727-4200)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
test
Assembly Version: 2.6.3.2
Win32 Version: 2.6.3.2
CodeBase: file:///C:/Users/Owner/Downloads/LobbyClient(2).exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.4016 (NetFxQFE.050727-4000)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 2.0.50727.4205 (VistaSP2GDR.050727-4200)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
enabled.
For example:
<configuration>
</configuration>
is the details if u need to know that
shifty
Lobby Username: sH1fty
Post by shifty »
i just deleted, and redownloaded lobby. i was having same problem. worked for me.
Edit: You're getting this error because you're running LobbyClient.exe from Firefox and some non-implicit programming 1. created the file there when it shouldn't have, 2. is now trying to delete it and you don't have admin permissions (programs without admin permissions can't modify the Program Files folder)
I'll have this all fixed with the next update. For now just go to your Firefox folder and delete userprefs.txt yourself, or directly run LobbyClient.exe instead of using Firefox to open it like my 60-year-old computer illiterate professors.
Post by ben55 »
The onlytime it "ran" from firefox was when I deleted it and downloaded it from your link.
Users browsing this forum: No registered users and 84 guests
