My brand spanking new scenario! Hold the base
President Obama
Lobby Username: President Obama
Post by President Obama »
HOLD THE BASE!
By President Obama A.K.A Sico Music
I have spent the last 2 weeks wasting my life to make this scenario. With the help of sexacutioner I managed to get it all done, except for the sniper which just wont work for some reason. Anyway heres a description of it.
Your base is in the middle of the map. Enemy's come from all directions at you, you must hold off the enemy's waves of attacks. There are 5 non stop waves in each round. In between each round is a break which heals all units and buildings. I'm not very good at describing things so your better off just playing it and finding out what its about. Oh the enemy also attack.
You can upgrade your hero or buy units from the shop with the kills you get. I tried to make this scenario harder then the rest.
It still has a fair bit of work to be done on it like hard core mode and medium (which by the way dont select as it doesn't work properly) I will work on these when someone manages to finish the scenario.
If you find any glitches, bugs or things that dont work, post a reply here or talk to me on the lobby.
I made a quick bat file. Run it and type the number corresponding the system you have. It will copy the file to the correct directory. It may not work, so you may have to do it manually.
It took me 2 weeks to make this scenario. I had some very late nights but I did it. It has 750 objects, 150 conditions, 1350 effects, 150 areas and 425 triggers. I also had to spend a lot of time remembering how to do things and getting help from sexa.
############UPDATE############
I have now updated it to version 1.1 After playing it today and noticing A LOT of the flaws I went through and fixed a lot of them and added quite a few more things. This is what I did:
• Fixed Civ names.
• Deleted BLUES Machine guns.
• Added wild card teleporter.
• Reduced spawn rate to reduce lag.
• Gave 350% more health to enemy shouldn't be so easy now.
• Added a wave of rams at wave 20.
• Added final bosses.
• Added mini boss wave every 5 rounds.
• Reduced the amount of attack brought for pillbox.
• Increased price of pillbox attack.
• Made Pandora way better.
• Fixed the looping catapracts wave.
• Change enemy size to 120%.
• Reduce pillbox range by 2.
• Fixed one of the boxes that had a task area effect in it.
• Start up chat.
############UPDATE 2!############
Updated again, to version 1.2. It actually works now, I think, heres what I did:
• Removed Pillboxes.
• Made the kill counter immune to deleting.
• Fixed how everything was spawning everywhere but the base.
• Readded a timer I left out.
• Healing Triggers - Still cant get them to work so failed :(
• Added hospital to make up for healing triggers.
• Unlimited Wood.
• Animals having food.
• Made enemy even stronger.
• Allied barb wire indestructible.
############UPDATE 3!############
Up to 1.3 we go, done quite a lot more.
• Freeze Teleporter walls.
• Stopped hero going into teleporter.
• Finally fixed the sniper.
• Once again made the units stronger. I'm pretty sure i wont need to make them anymore stronger now maybe weaker.
• Rearranged the waves into hitpoints order.
• Increased sniper reload time so it shoots slower.
• Fixed boss wave 2 speed and attack.
• Maceman speed fixed.
• Shorten beginning build time.
• Made shop units much better.
• Upgraded Purples and Cyans Pills.
• Downgraded all pills attack.
• Shortened animal rounds.
• Buying hero range. Eg Purple would buy it and it would take gold away from BLUE - fixed.
• Hero round increased attack and health.
• Fixed being able to get both heros.
• Add autostart.
Things to be decided on:
• Limiting pillboxes and towers to stop people spamming them and stealing kills
• Have stone miners instead of infinite stone. I'm not sure because people can just glitch stone.
• Having trees for cutting.
• Bamboo Towers
• Making boss wave speed slow but have a lot more health and attack.
THIS SCENARIO IS FOR AOC ONLY! Sorry forgot to mention that.
Here's a screen shot: Thanks to Pelie for helping me work out how to take them in ee.
Heres the download link for ee heaven:
http://ee.heavengames.com/downloads/sho ... ileid=2633
Heres the download link for megaupload:
http://www.megaupload.com/?d=KHV5I9BH
Have fun.
Last edited by President Obama on Tue Apr 06, 2010 1:21 am, edited 9 times in total.
inola
Re: My brand spanking new scenario!
Post by inola »
Anyone try this scen yet?
Wyrda
Post by Wyrda »
inola wrote:Anyone try this scen yet?
We just finished playing it for the first time... It still needs some work and I think Obama is counting this as a kind of beta version to be tested and fixed.
The units were very very easy to kill, as you can simply mass pillboxes and/or laser towers until all the space is filled. Engineers and citizens are very cheap to buy, so massing is easily done. The idea was that your buildings would be destroyed by the units fairly fast so this wouldn't be such a problem.
Obama said he is going to make a limit on how many pillboxes you can build (30), and the number of towers (40), and make the units much tougher in terms of health and attack, as well as increase some prices on buying upgrades/units.
It was also quite laggy, but I'm assuming that's from the large number of pillboxes, and large number of units spawning, which should both be fixed with the edits.
It was pretty interesting gameplay, it just needs a few changes and some more testing.
Sounds good :)
Re: My brand spanking new scenario! Hold the base
It doesnt have any zombies, like i said it should.
Pinky
Post by Pinky »
add zombies
President Obama
Peow, what do you define as zombies? Adding a heap of lag effects or is there a specific unit? Or do i just change the class name of all the enemy to zombies?
Pinky
Post by Pinky »
The Walking Dead. Scientific name Homo Coprophagus Somnambulus.
A deceased human being who has partially returned to life due to undeterminable causes. The brain retains base facilities, namely gross motor function. In its near-mindless state, it grasps no remains of emotion, personality, or sensation of pain.
President Obama
So how do I add that into my scenario?
Users browsing this forum: No registered users and 26 guests
