how to......
CARLOS
how to......
converting saved game of a .scn file. i dont get it. dont u just rename for .scn and put it in scenario banilla folder?
Re: how to......
.scn is for the editor
.ees is for actually playing with others
right click what you want then select rename
FILENAME.snc or FILENAME.ees <------- if it dont say this and it just says FILENAME with no .scn or .ees then you have to go to folder options and in the view tab make sure you uncheck the " hide extensions of known file types " this will make is so the .scn or .ees will show up for renaming (if you dont do this then you will end up with a FILENAME.ees.scn which will only open as a scen file in the editor )
scn files can only be opened with the editor
ees files only through single or multiplayer
CARLOS
Re: how to......
i have a .ees and i delete the .ees in rename and put .scn but it remain a .ees file. is confusing....
Re: how to......
change your folder options as i said to do
ees files belong in saved games
scn files belong in scenarios
Users browsing this forum: Google [Bot] and 37 guests
