lobby update
thor
- Lobby Username: pM_Thor
lobby update
when I run the lobby, an updater appears. it wants to change my sierra files, I don't want it to. but there is no way to close the window (a try on forcing everyone to update) unless I open Task Manager and manually end the process
pM_Thor
- PeLlE
- Xfire: thepelie
Re: lobby update
it asks you if you realy want to remove... simply click no maybe?
d-dog
- Lobby Username: Cold Fusion
Re: lobby update
O, I guess im not aloud to say thatthor wrote:when I run the lobby, an updater appears. it wants to change my sierra files, I don't want it to. but there is no way to close the window (a try on forcing everyone to update) unless I open Task Manager and manually end the process
thor
Re: lobby update
what do you meanPeLlE wrote:it asks you if you realy want to remove... simply click no maybe?
pM_Thor
d-dog
Re: lobby update
there is no buttonPeLlE wrote:it asks you if you realy want to remove... simply click no maybe?
d-dog
Re: lobby update
O btw, is there a rule against positive saracsm? If so inform me now, and you can delete my previous post. Just have to make sure, cause you can get banned for some many different things at this place, theres alot of unsaid rules for this place.
- inola
Re: lobby update
Go into your lobby client folder and delete PatchUpdate.exe a new gay window at login will open just say OK
thor
Re: lobby update
thank youinola wrote:Go into your lobby client folder and delete PatchUpdate.exe a new gay window at login will open just say OK
pM_Thor
