Since scenarios are a thing again
After drex mod we can host scens again so I took the time to fix a few ones that I really like:
H&R scen is generally really good, but a lot of players complained about Napoleon being too strong. I took it down from +1500 attack to +500. This means it 3 shots pillboxes, 2 shots arquebus with morale and 1 shots arquebus without morale.
I also took away the instructions popup, made the engineer have same speed as all the other units. You no longer have to upgrade range on your pillbox, delete one of those heroes for +1 pop.
H&R Classic map:
- -H&R - 4 PLAYER fixed by Arntzen.scn
(180.43 KiB) Downloaded 517 times
- -H&R - 8 PLAYER fixed by Arntzen.scn
(114.36 KiB) Downloaded 498 times
H&R with more open map:
- -H&R - 4 PLAYER w open map fixed by Arntzen.scn
(181.74 KiB) Downloaded 494 times
- -H&R - 6 PLAYER w more roads fixed by Arntzen.scn
(186.19 KiB) Downloaded 476 times
- -H&R - 8 PLAYER w open map fixed by Arntzen.scn
(115.38 KiB) Downloaded 485 times
Defender:
- Defender3.4-by_DarthMaul Fixed by Arntzen.scn
(140.08 KiB) Downloaded 496 times
Tell me if you want me to edit/change/fix some other scens. Will probably add them here when I've finished them.
drex888
Lobby Username: Drex888
Re: Since scenarios are a thing again
Post by drex888 »
Nice job bro!
"Bridge Crossing by Lilbeni Mush XV v2.0---.scn" for 8 Players?
Bridge crossing 5.17 by hitler was the best. (AoC)
