Graphics problems with Windows 8
omar.2
- Lobby Username: omar.2
Hi everyone.
I have Windows 8.1 and just downloaded EE Gold Edition from gog.com (which claimed that it is Windows 8 compatible!)
I had 2 issues: graphics and freezing.
I implemented the changes suggested on these forums to fix the freezing (by going to registry and changing 2 files).
But the graphics are a real problem. They flicker and glitch in the screens and in the game. I attached a screenshot.
Does anyone know what may be causing this and how I can fix it?
My graphics card is Intel HD Graphics 4000.
Thanks!
Thanks!
Re: Graphics problems with Windows 8
Download one from the save-ee forum or www.neo-ee.net (or neoee.net not sure...) hf
omar.2
Download what exactly? I saw there's a patch available but it seems like the patch is meant to enable multiplayer, not to fix graphics problems?
omar.2
My problem seems to be the same as one in the solved problems section but I can't figure out the solution that was posted.
viewtopic.php?f=7&t=3707
I gave it a whirl on my new Windows 8.1 laptop and couldn't find a fix for the same issue.
I tried just about every combination of settings between the Intel HD control panel, EE, and the Windows compatibility settings. I'm not sure if the incompatibility is with Windows 8.1, DirectX 11, or the drivers (my drivers are the latest, won't be reverting because they fix other issues).
I think we finally reached the point where EE is too old for modern graphics hardware/software.
My graphics info, just FYI
Code: Select all
Intel(R) HD Graphics 4400
Report Date: Monday, April 21, 2014
Report Time [hh:mm:ss]: 9:04:20 AM
Driver Version: 10.18.10.3496
Operating System: Windows* 8.1 Tablet PC Edition(6.3.9600)
Default Language: English (United States)
Installed DirectX* Version: 11.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.2
OpenCL* Version: 1.2
Physical Memory: 8106 MB
Processor: Intel(R) Core(TM) i7-4500U CPU @ 1.80GHz
Processor Speed: 2394 MHz
Vendor ID: 8086
Device ID: 0A16
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4400
Graphics Output Protocol (GOP) Version: 5.0.1031
Current Resolution: 1600 x 900"Nothing is foolproof to a sufficiently talented fool."
GoGo
- Lobby Username: GoGo
I have same problem
My grafic adapter is Intel(R) HD Graphics 4000
i have lenovo G 700 64bit windows 8.1.
i need to uninstall windows 8.1 to 8 to play EE.
Black Star
- Lobby Username: Die Gurke
Same Issue with Intel HD 4600 and win8.
Postby GoGo » Wed May 07, 2014 3:12 pm
I have same problem
Try what gogo said some reason gog ee dont support 8.1 but 8 should run fine
I have same problem
GoGo
Problem is resolved.
I have found this solution on Lenovo G700 windows 8.1. No need downgrade to windows 8.
Just Disable automatic driver install like here: http://www.microcentertech.com/tech_cen ... 06661B.htm
Go to windows update and search for the new drivers then hide the Intel Corporation Graphics Adapter WDDM1.2 , WDDM1.3 Graphics Adapter - Intel(R) HD Graphics.
Go to Device Manager, remove the graphics driver. maybe need removing few times.
at the end you need to install the Intel(R) HD Graphics 4000
for windows 8. and restart.
enjoy
enjoy
Nice work GoGo!
KSA_Knight
- Lobby Username: KSA_Knight
Hi gogo,
I have Lenovo, T440p, windows 8.1, and I'm unable to run the EE1 in my laptop. I tried using the method that you described but when I wasn't able to install Intel(R) HD Graphics 4000; it indicates that this is for 3rd generation laptop and it can't be installed in your laptop, 4th generation.
Do you have a way to install Intel(R) HD Graphics 4000 or any other method to make EE1 run in windows 8.1?
Appreciate your help
- Hello0
- Lobby Username: GoG_hΣ||øØ
yea same here, didnt work for me either.
Any other solutions found already?
I am sweet.
its intel 4000 hd what causes the problems i already posted to intel and they say its the manufacture you have to speak to so they are just passing the blame.
Black Star
ya for me its not even windows8 related had same issue with win 7 and intel 4600
basti-sk
- Lobby Username: basti-sk
same problems with win 8.0 and Intel(R) HD Graphics 4400.
is the problem solved? - I need to kill Earth again...
I couldn't solve it, but tried really much..
is there anybody there who can help me with that problem, maby with teamviewer, I would appreciate it if you can help me..
basti-sk
basti-sk
