delte user names
- Eisregen
- Lobby Username: Lycantropia
delte user names
how can i delte my usernames from the save ee lobby have so much its annoying.
always need seach right,
xdfsddsvfdsvvadf
Re: delte user names
Find the file user.config which should be in a folder similar to the following:
XP:
Vista/7:
So for example mine is:
Open the file in Notepad or similar file editor and find the portion:
and then change it to the following:
XP:
Code: Select all
C:\Documents and Settings\<username>\Local Settings\Application Data\Save-EE\LobbyClient.exe_Url_<GUID>\<current lobby version>Code: Select all
C:\Users\<username>\AppData\Local\Save-EE\LobbyClient.exe_Url_<GUID>\<current lobby version>Code: Select all
C:\Users\matt\AppData\Local\Save-EE\LobbyClient.exe_Url_da1ibvmcop1ds4hqk5o5hnaryz3sf0bg\2.6.5.0Code: Select all
<setting name="Usernames" serializeAs="String">
<value>[bunch of gibberish that is username/password data]</value>
</setting>Code: Select all
<value />
</setting>"Nothing is foolproof to a sufficiently talented fool."
- Eisregen
- Civ Nazi
- Lobby Username: taco
if ur trying to smurf without ppl finding u out, that works, but mods can still detect all of them. i think it takes them abit longer to figure out tho
- Trichome Indica
Could also delete your user file and re-instal lobby client.
I'm pretty sure (not a 100%) that all usernames are stored on the server, so that even if you remove your userfile it still is available for moderators & admins and who ever hacks the server.taco wrote:if ur trying to smurf without ppl finding u out, that works, but mods can still detect all of them. i think it takes them abit longer to figure out tho
_thor
- Lobby Username: pM_Thor
just rename your lobby exe ?
{Sauerkraut>}I love you: boom or rush this is the uesatinoin , i love shakespearei
Some people might want to keep the other settings
