• Empire Earth
  • Miscellaneous
move units from an area to another
Postby CAV_range » Thu Oct 31, 2019 3:51 am
i have an effect so units move-attack to a specific area, so i want these units once they reach this area, they move to other, is it possible? i tried playing with effect and so but i have not found a way yet, has anyone tried this?
CAV_range
Re: move units from an area to another
Postby Neotje » Fri Nov 01, 2019 1:28 pm
This should be possible. Check the MTP scenario, it does something like this, it moves units from position A to position b, but on a kind of 'pulsed' order. On Vortex TD, units are removed (the babies) when they hit a certain spot. You might be able to combine those.
Or don't you mean teleport? If you don't mean teleport, check the above to trigger an action on a unit once it reaches a position, and use as an action the move-attack.
Neotje
Postby CAV_range » Fri Nov 01, 2019 8:04 pm
Neotje wrote:This should be possible. Check the MTP scenario, it does something like this, it moves units from position A to position b, but on a kind of 'pulsed' order. On Vortex TD, units are removed (the babies) when they hit a certain spot. You might be able to combine those.
can you share the scenario? i did not find anything about "MTP", thanks
CAV_range
Postby CAV_range » Sat Nov 02, 2019 2:11 am
ok I think it means "Massive Tower Protection", and i realized how to do it, thank you. in case someone wants to know how to do it:
example:
- create an area ( area A )
- create an area ( area B )
- create an area ( area C )
- create an object for all units ( object A ), set its Area to are A
- create an object for all units ( object B ), set its Area to area B
- create an object for all units ( object C ), set its Area to area C
- create an effect task-area ( effect A ), set its Object to object A, set its Area to area B
- create an effect task-area ( effect B ), set its Object to object B, set its Area to area C
- create an effect task-area ( effect C ), set its Object to object C, set its Area to area A
- create a trigger ( trigger A ), set looping on, set its Condition to object A ( if they exist ), set its Effect to effect A
- create a trigger ( trigger B ), set looping on, set its Condition to object B ( if they exist ), set its Effect to effect B
- create a trigger ( trigger C ), set looping on, set its Condition to object C ( if they exist ), set its Effect to effect C
with this any unit created in area A, area B or area C will move to the next over and over ( area A > area B > area C > area A and so on ) i hope it is understood.
CAV_range
Postby Neotje » Sat Nov 02, 2019 3:37 pm
CAV_range wrote:ok I think it means "Massive Tower Protection", and i realized how to do it, thank you. in case someone wants to know how to do it:
example:
Yes! Massive tower protection, sorry, it's a default name for me, but I don't think it has been popular for a while, so I should have written it out.
Glad it seemed to have helped.
Neotje
Postby Alisontog » Fri Dec 20, 2019 12:50 am
I tried searching the forum for an example but i couldnt find any. I need a way to copy a record from one table to another.
Any suggestion or hints on how to achieve this?
Alisontog
Return to Scenario Discussion
