Greetings to you all,
since I decided to play the game more oftenly I did a reinstallation of your lobby program. With that, I lost most of my names.
Thus, I am asking if it is possible to give me a list of my names as I assume that you keep log files on such.
Lost my lobby names
snupi
- Lobby Username: ugug
Re: Lost my lobby names
We do not keep log files which have lists of associated usernames. Usernames have to be matched manually under several criteria in order to produce such a list.
In the past, it has been our policy that we do not retrieve lost lobby usernames. You should keep your own record of your usernames, back up your settings, use less names, and/or pick usernames that are easier to remember.
We will provide only a primary alias under special circumstances, if it becomes corrupt, or in the event that someone other than the rightful owner registers/steals the username before they get the chance to register it themselves.
Because you're such a huge smurf, I'm sure it won't be hard for you to register some new names. If there's names that you hold ever so dearly to your heart, then you wouldn't need to be asking for them here. I'll give you the option of requesting ONE username, if you are able to describe it significantly, and I will not be providing you with a password.
