Hi i would like to make a Video for training purposes on EE training section via LOBBY client.
I noticed their are some MID sh games but not MID DM CAV.
I used to play this game type back in the old days and to be honest it doesnt have any flaws and i never lost a match with it.
if there is any chance some one get back to me and allow me to make a video and put it up on lobby that be great. thankyou.
Valcone@live.co.uk
[-Sc-]<<Sparky>>
EE video training surgestion
- Lobby Username: Sparky
Re: EE video training surgestion
When I said to post here I meant to post the video as well.
illgo make it in a minute then just helping a friend get EE
You should record your video using FRAPS and then compress it using these steps:
Notes:
Because FRAPS will break your recording into multiple files if it's long, you'll obviously want to make them one file. When you're in VirtualDub (Step 3 of above), you want to open the first segment. Before going to Step 4, navigate to "File -> Append AVI segment..." and pick the next part. Do this for each part, in order, then proceed to Step 4. After it's all finished it will be one video file.
After you have the AVI file, just upload it to YouTube. Post a link to it and the civilization you used here and we'll add it to the Training tab for the lobby.Omega wrote:How to compress your videos, for the technically challenged.
Step 1:
-Make sure you have DivX Codec installed. [Just get the free version]
-Download virtual dub, google will find it for you. Install it.
Step 2:
Run virtual dub.
Step 3:
Open the first video file in virtual dub by going to File -> Open Video File
Open the file.
Step 4:
Click Video -> Compression
Select DivX Codec
Select Configure
Step 5:
If you don't know what you're doing, select the 1080HD profile. Make sure to follow the constraints of:
1280x720 at 60 FPS or less
Don't record any higher resolution footage, and don't record at any higher FPS. (Note: You should see how many frames per second you get in-game while you are recording before you set what FRAPS records at... Since there's no point in recording at 60 FPS if you're getting 20)
Step 6:
Cick on Video, and make sure Full Processing Mode is set.
Step 7:
Go to File -> Save as AVI.
Save it as whatever you want.
Wait until its done. Feel free to do other stuff regarding other programs.
Step 8:
When its done, play the newly compressed video back to make sure it looks fine, etc.
If it looks fine, delete the massive uncompressed video Fraps created.
If doesn't, or doesn't play, odds are you failed massively.
Notes:
- White Fang
can we get a training vid of tricky getting like 150 pop or something in f11 10 O_o? i would watch that all day O.O
edit:in mid sh using cav qarchers O_o
- LacRimoSa
impossible, trickys comp crashes with pop higher than 98.
- Hello0
- Lobby Username: GoG_hΣ||øØ
Users browsing this forum: No registered users and 41 guests
