IPv6
Re: IPv6
IPv6 is the successor to IPv4. Basically it is the protocol standard for transferring packets over a network. IPv4 uses 32-bit addresses where IPv6 uses 128-bits. That you have limited IPv6 connection only means that there is currently no IPv6 communication with your machine, which is not at all unexpected. IPv6 is still hardly used.
