• Empire Earth
  • Miscellaneous
Crashes on Start Up
Crashes on Start Up
Postby N66PLZ » Thu Jul 11, 2019 10:49 pm
Hello,
Whenever I start the Neo Patch of EE and after I go through the Entry scenes it simply just crashes. I can't even make it to the lobby.
Here's a video of it starting up... If it helps :)
https://drive.google.com/open?id=1OB1eZ ... c8F9VmXaVx
Thanks.
N66PLZ
Re: Crashes on Start Up
Postby Arntzen » Fri Jul 12, 2019 7:44 am
When installing EE and NeoEE patch did you encounter any error messages?
Where did you get your EE from?
Did you try running EE in different compatibility modes? Run as admin?
My bet is that something went wrong in the installation process. Maybe opening NeoEE patcher again and hit repair can fix it. If not you might have to do a complete reinstall. I recommend following these guides:
How to install Empire Earth and Art of Conquest: viewtopic.php?f=131&t=11070
How to install NeoEE patch: viewtopic.php?f=131&t=11069
Return to Support
