Hi there,
I've been trying to host an online game but it didn't work.
Everytime I try to host a game I get a warning says: "NeoEE was not able to verify that your machine can accept connections. Other players may have difficulty joining."
I've already forwarded ports but I still get the same warning and can't start a multiplayer game.
Can you please help me with this issue?
Thanks in advance.
Multiplayer issue
- NeoEE Developer
Re: Multiplayer issue
Are you sure you did it right? The ports are 33334-33336 TCP+UDP. Use your local address (IP) to forward. Make sure that Windows Firewall also accepts EE.
- Lobby Username: Ts-SneakyY
If you port forwarded correctly ports 33334,33335,33336 TDP and udp then just ignore that, host the game anyway and it should still work
